Oppo BD-83: can one make it region-free (is it easily hackable) ?
0 Members and 1 Guest are viewing this topic. Read 3933 times.
Art_Chicago
According to videohelp.com, seems like it is easy to decode Oppo DVP's, but how about the BD-83? Please share your experience. I see they sell special devices on e-bay (made in Denmark, apparently) for this purpose, but I'd like to avoid opening it and installing extra parts.
JP78
i was told by oppo there's no way to make the oppo blu-ray players region free without opening it up; they provide some cable with a microchip in it that needs switched out for overseas orders.  for all the ones we've sold overseas to clients i know they've had to be hard-modded.
« Last Edit: 27 Aug 2009, 05:47 am by JP78 »
JP78
thanks for the tip! right now it cost us something like 30usd for the cable to unlock the oppo. i'll be sure to try it out when i find some time report back.
JP78
http://www.codefreedvd.com/dvd_oppo_bdp83_multiregion_firmware.html
Works perfectly.
hey just a quick follow-up on this. this firmware update has several reports of the older version not being dvd-a compatible, and the newer beta version has some bitstream issues. if dvd-a is not a priority for you, than the fix is ideal.  good luck.
Eric5676
    • Blu Ray Oasis
Works perfectly.
Thanks for the info. :)
