0 Members and 1 Guest are viewing this topic. Read 7897 times.
Yes very nice room James and the speaker cabinetry matches your hardwoods nicely. Hey what do you use that little cubby beside the left speaker for? ...... I am such a nosey B
JamesIs the 10B crossover the one you had modified several months ago and what is the little screen above it (sorry for being nosy)Steven
That is looking good James. Hope it sounds as good as it looks. I'm sure it's a step forward from the IB2s (less dry and more of a relaxed sound than before?)If that piece below the computer is indeed a cross-over, what's it doing in this setup?
Quote from: Viajero5000 on 5 Sep 2009, 08:32 amThat is looking good James. Hope it sounds as good as it looks. I'm sure it's a step forward from the IB2s (less dry and more of a relaxed sound than before?)If that piece below the computer is indeed a cross-over, what's it doing in this setup?It is the Bryston 10B Sub crossover I use to integrate Subs into different systems I set up in that room.james
