Emerald Physics and Apple Computer Audio System
0 Members and 1 Guest are viewing this topic. Read 1588 times.
Michaelnelson
« on: 23 Aug 2009, 02:47 pm »
Emerald Physics is at it again. Not only do they have the new wonderful CS2.3, but Clayton is in the works on a Apple based Computer audio system that is going to Destroy everything out there.  That company is so cutting edge it is crazy.  Has any one else heard about it?
low.pfile
Re: Emerald Physics and Apple Computer Audio System
« Reply #1 on: 23 Aug 2009, 03:04 pm »
Where did you learn about it?
Have you heard it yourself?
Michaelnelson
« Reply #2 on: 23 Aug 2009, 03:17 pm »
i contacted Emerald Physics and they let me in on it.  Yes I heard it.  OMG this thing was great.  With his system you can remove his DSP.  it is an Apple based system that also has room correction.  Unlike the other products that are Cd players that use storage.  This is a Computer that is based on itunes. with audio added to it
zybar
« Reply #3 on: 23 Aug 2009, 03:31 pm »
Is this using Amarra?
George
Michaelnelson
« Reply #4 on: 23 Aug 2009, 03:45 pm »
No it does not. Amarra is a very god sounding system.  VRS has a high end system, that uses Amarra but I have found it to be troubled and complicated to use.  This system sounds just as wonderful and is simple to use,with room correction
ted_b
« Reply #5 on: 23 Aug 2009, 03:49 pm »
These next 24 months, especially with Snow Leopard and 64 bit, will likely produce some very powerful MAC apps for us music server folks.
Michaelnelson
« Reply #6 on: 23 Aug 2009, 04:11 pm »
you are so right.  Apple is a mass media power house but they are thinking about the people who not only care to listen to music but want to hear it in a quality format
