Neo3 in white oak
0 Members and 1 Guest are viewing this topic. Read 2123 times.
REY
Neo3 in white oak
« on: 23 Aug 2009, 01:55 pm »
nothing too special here but the speaker itself, I still don't know what I am going to do with the bases, paint them black or veneer them. these are my third pair of GR research speakers, and so far these are the best.
RogerB
Re: Neo3 in white oak
« Reply #1 on: 23 Aug 2009, 04:44 pm »
Those are beautiful!  If you have a chance I would love to read your impressions of the sound of these baby's.
Again, they are beauts!!
Roger
Nick77
« Reply #2 on: 23 Aug 2009, 06:48 pm »
Those look awesome. I vote for a roundover on the edges and painted black for the base. :)
cujobob
« Reply #3 on: 23 Aug 2009, 08:51 pm »
Nice looking speakers...as for the base, I'd veneer it.
tmoney1876
« Reply #4 on: 25 Aug 2009, 04:18 pm »
This makes me feel happy about the set of N3S's that I am building...  :thumb:
Ron
« Reply #5 on: 25 Aug 2009, 06:30 pm »
 Your Neo 3's look great! Nice job. I suggest that you paint the bases black. When I built my AV-3's last year,I made the bases by laminating two (2) pieces of 3/4" MDF together and putting a radius on the top edges using a 3/4" round over bit in my router. I then sanded the bases smooth with 220,320,and then 400 grit sandpaper;wiped throughly with a tack cloth;and then applied a coat of Minwax sanding sealer. After that I sprayed with multiple coats of satin black Krylon Fusion spray paint, lightly sanding with 600 grit sandpaper and wiping with a tack cloth between coats. The attached pictures gives you an idea of how they look.
Ron
REY
« Reply #6 on: 26 Aug 2009, 05:52 pm »
those bases look pretty awsome, I already have the krylon black laquer, I might give it a try this weekend.
