Keces 131 MKII
0 Members and 1 Guest are viewing this topic. Read 906 times.
silverr1
Keces 131 MKII
« on: 20 Aug 2009, 11:11 pm »
Looking to sell my Keces 131 MKII DAC to fund an upgrade. It's in excellent shape. $250 plus shipping.
KECES DA-131 Mk2 Basic Specs:
1. BurrBrown PCM1793 DAC: High performance Advanced Segment 24bit/192KHz DAC.
2. Cirrus Semiconductor CS8416 Receiver: High performance SPDIF receiver with 24/192KHz support
3. Coaxial and Optical input: Supports coaxial and toslink optical input, signal quality is maintained by direct connection without passing signal through any switches.
4. National Semi LME49710: State of the art precision operational amplifier, the ultimate in low distortion, low noise and high performance.
5. Fully Balanced DC Coupled Circuit: No signal distorting capacitor or DC servo in the signal path, with fully balanced circuit to provide even better sound.
6. Quad Independent Power: Four independent regulator circuits, with two dedicated to digital circuit and two dedicated to +/-15V analog power for LME49710 OP-Amp.
7. 2VRMS Standard Output: Industry standard 2VRMS output level, ensuring excellent compatibility with your stereo equipments.
8. International Voltage Compatibility: Simple flick of a switch will allow you to switch between 115V (usable for countries of 100 to 125V) and 230V (usable for countries of 200 to 250V).
9. Dimensions: 215mm * 205mm * 80mm (Width * Depth * Height), it is the same size as other KECES products, allowing easy placement of the unit.
