tempest with 2 output set
0 Members and 1 Guest are viewing this topic. Read 2029 times.
Christophe35
« on: 18 Aug 2009, 11:10 pm »
Hi,
I read that some tempests have 2 set of output. Does this add 2 rca to the tempest or some already existing rca are used for the second output ?
Is there somewhere pictures of a tempest with 2 set of output (inside and outside) ?
Thanks  for any information
« Last Edit: 19 Aug 2009, 12:49 pm by Christophe35 »
Ptisik
Re: tempest with 2 output set
« Reply #1 on: 21 Aug 2009, 03:44 pm »
Anyone can help please ?  :oops:
Musky_Don
« Reply #2 on: 23 Aug 2009, 03:55 pm »
I have a Tempest with 2 outputs.  Adds an extra set of rcas.  It was some time back but I think I asked Klaus to add for hooking up a sub-woofer.  I then decided that my Monitor Audio sub could not keep up musically with my Dynaudio speakers and dropped the sub in for HT only (I have a HT bypass as well).  It has been years since I used the 2nd outs.  That is my recollection.  If you send me a PM with an email address I'll shoot you a quick pic.  I am travelling this week and can't remember the process for imbedding in AC.  Hope this helps.
Don
Sonny
« Reply #3 on: 23 Aug 2009, 03:58 pm »
I too had a Tempest with two sets of outputs.  It really is just one set internally and jumped to another set.  They are essentially the same R/R and L/L.
Hope this helps.
T
mjosef
« Reply #4 on: 23 Aug 2009, 10:31 pm »
The Tempest I have also has two outputs, one set looks to be of better quality and are laid out horizontally. The other "normal' looking set are vertical and look like the rest of the input RCA.
Ptisik
« Reply #5 on: 26 Aug 2009, 07:59 pm »
Thank you  :wink:
But .. anyone can make one or two (or more) pictures please, I want to be sure before I modify mine  :oops:
Thx !
mjosef
« Reply #6 on: 27 Aug 2009, 05:39 am »
Ptisik
« Reply #7 on: 27 Aug 2009, 05:50 am »
Thank you mjosef, if someone has inside pictures too, it will be perfect !
klaus@odyssey
« Reply #8 on: 28 Aug 2009, 05:14 am »
OK,  it is an easy setup, soldering jumpers to the primary connectors.  HOWEVER,  holes have to be drilled for the extra RCA's.
Ptisik
« Reply #9 on: 28 Aug 2009, 05:21 am »
Ok thank you, I think I will do it next week  :thumb:
