0 Members and 1 Guest are viewing this topic. Read 20905 times.
Reducing phase distortion throughout the system is what improves soundstage imaging. Make the speakers same distance from tweeter to ear in the listening position, and same toe angle. If your room is large enough get the speakers and yourself as far away from the walls as possible so early reflections are minimized. Then toeing out a little helps ambience. If the echos arrive at your ears long enough after the direct sound from the speakers then the added echo does not detract from soundstage. In a small room treatments like absorption or diffusion can work better because you can't get far enough away from the walls. The front wall should be hard and flat with nothing placed between the speakers. No soft stuff anywhere on the front wall for best soundstage.Amplifiers (pre and power) should have linear phase through most of the frequency range. Tube amps are naturally good at this, but a good SS designer can do it. Speakers should have linear phase crossover which is a lot easier to achieve with 2nd order than 4th order passive filters. Drivers should be time aligned at the listening position. Reduce digital jitter, clean AC power, no ringing in signal wires. Presto! excellent imaging. But imaging is just a parlor trick compared to clean flat satisfying bass response in the room and accurate timbre and PRAT from the amps and source.
Are room treatments the key as well as the equipment? I have Merlin TSM-MMe which are pulled out a least 6 ft from the wall, and 4 ft from the sides. Upstream they are driven by a Stan Warren Aiwa XC-35/MSB DAC>Odyssey Tempest SL>Stratos Monos. IC are Gronenberg TS and speaker wire is Reality. Bass is handled by 4 GR servo OB subs.While the speakers disappear, the sound stage really isn't wider than the speakers or particularly deep.Right now I have 2 GIK 242 at first reflection points on the side wall, and one across a rear corner as a bass trap. Would adding a lot more broadband absorption help w/ sound stage?I should think imaging from the Merlins would be excellent.
In addition to the original question, what treatments have the most potential to create this? I would assume first reflection points...but then, something next?
