0 Members and 1 Guest are viewing this topic. Read 2658 times.
Hi, everyone. I'm a new Offramp owner, Steve's instruction states that the Offramp should be powered up then the usb cable installed. Locus instructs the opposite, install the cable while the Offramp is off. How do you owners do it? Thanks, Steve.
Steve,I have two SR3 power supply customers that have mentioned problems with startup on the Off Ramp. They have to power the Off Ramp before energising the computer. The SR3 has a slow run up to full voltage. Is this likely to cause boot-up problems. I can speed the run-up if this will help.RegardsPaul
Thanks for the info. I also noticed that even when my computer is off, the green and red lights are still lit. Is it ok to keep it powered or do you all power down when not using it for a while?
Quote from: slee on 17 Aug 2009, 08:01 pmThanks for the info. I also noticed that even when my computer is off, the green and red lights are still lit. Is it ok to keep it powered or do you all power down when not using it for a while?I leave mine powered up all the time.Steve N.
Thanks Steve,How quickly should the full supply voltage be available.RegardsPaul
