What type of Devices are connected to your BDA-1
0 Members and 1 Guest are viewing this topic. Read 6399 times.
Dilbert
Re: What type of Devices are connected to your BDA-1
« Reply #20 on: 18 Aug 2009, 12:25 pm »
What is a Squeezebox? :oops: Please also note "the deer in the headlights" look... :o
Thanks...
Don't listen to Werd, he's obviously a trouble maker.... :nono:
Here:
http://www.logitechsqueezebox.com/products/overview.html
Laundrew
« Reply #21 on: 18 Aug 2009, 11:09 pm »
Thanks...
Here:
Thank you Dilbert :thumb:
drummermitchell
« Reply #22 on: 4 Sep 2009, 05:27 pm »
Just checked out the new Squeezebox(the touch)out in december.
I believe she'll act as a music server,will pass 24/96 and also a 32 gig card slot
It will be quite interesting to see how the reviews go when she's out.
KeithA
« Reply #23 on: 4 Sep 2009, 09:12 pm »
Next week a Transporter will replace an SB3 8)
Keith
dubkarma
  • "God made man because he loves stories." - Canetti
« Reply #24 on: 6 Sep 2009, 10:22 pm »
In the case of my BDA-1, a heavily modified Teac VRDS-25X (1998) feeds the AES/EBU digital input with the balanced analogue output feeding a BP-26, which drives a Son of Ampzilla 2000 power amp which drives Tannoy System 15 DMT II monitors. So far, I can't tell the difference between having the upsampling on or off.
john1970
« Reply #25 on: 6 Sep 2009, 11:26 pm »
The Squeezebox Touch does support 24bit / 96kHz sampling rates and can play back files off a USB drive or SD card.  I have been looking for a device that supports high-res downloads from a memory card playback.  Once it becomes available I will have to pick one up for $300 and plug it into my BDA1.
Thanks for pointing this out.
drummermitchell
« Reply #26 on: 7 Sep 2009, 12:24 am »
That's what I want to do also,then I've justified purchasing the BDA-1,I'm waiting for my Alesis 9600 CDR,(replaced my HHB cdr)I believe that can go out
of the digtal bypass output of the BDA-1 into the Alesis.
I did (finally) run my sat receiver into the BDA,not bad,some stations so,so.
For background music,alot better than the TV speakers :thumb:.
Dilbert
« Reply #27 on: 7 Sep 2009, 12:02 pm »
One of the things I really appreciate about the BDA (besides the sound quality) is the usefulness of having multiple digital inputs that are switchable via the remote.
The remote was a good investment even though I don't use a Bryston preamp. :roll:
alexone
« Reply #28 on: 7 Sep 2009, 01:52 pm »
hi, all!
what do you think?
my computer has a analog stereo input. and i'd like to do some recordings from a Minidisc recorder. i am using the coax from MD to BDA-1.
now what analog output should i use?
1) the BDA-1's analog outs (unbalanced in this case)
2) the BP26's analog tape output
the XLR outs of the BDA-1 are connected with the 26. that way the recording is still audible.
al.
KeithA
« Reply #29 on: 13 Sep 2009, 09:26 pm »
The newest addition....
Keith
drummermitchell
« Reply #30 on: 13 Sep 2009, 09:46 pm »
Very nice Keith,I like that.
KeithA
« Reply #31 on: 14 Sep 2009, 11:01 am »
It's a nice rig. If I ever get bored someday I'll try the DAC in the Transporter against the BDA-1 :wink:
At least I can dabble with some of the other hi-def file formats (as you can see the BDA-1 is actually locked into a 24/48 signal in the pic. So, that part works :)
Keith
drummermitchell
« Reply #32 on: 14 Sep 2009, 01:57 pm »
Keith,it will be interesting for me to see what you discover musically with the transporter and  the BDA-1 8),something else for  me to think about.
I could and might try out a squeeze box just to see if it can satisfy me a little more,course were never satisfied.These devices do open up a lot more doors
and hopefully i'll like what I hear :thumb:.
drummermitchell
« Reply #33 on: 16 Sep 2009, 01:15 am »
                                      NEW TOY
                                 WHEW,a bit better photo :o.
Robert D
« Reply #34 on: 16 Sep 2009, 12:22 pm »
Keith
Great Pic
Robert
Robert D
« Reply #35 on: 16 Sep 2009, 12:25 pm »
Don
Great Pic
Robert
KeithA
« Reply #36 on: 25 Sep 2009, 11:53 am »
Keith
Well, i guess last night i inadvertantly compared the BDA-1 to the Transporter DAC :duh:
I buddy loaned me a new set of RCA cables to try so I hooked them up night before last. So, last night I figured I'd just listen to some music and try to see the impact of the new cables.
I powered up the stereo and started listening to an album that I'm really familiar with (and I play to death!). It all sounded great on most stuff, but the more busy passages I thought weren't as clear. I thought, funny that the cables (Furutech) seemed to be not as good as the ones i would be replacing if I went with the new ones :scratch:
It still sounded good...just something was amiss from time to time. Then i noticed the red light over the BDA-1 power switch....so, if the BDA-1 is not on....what am i listening to!!!
Turns out I accidentally plugged the RCAs into the Slim Devices Transporter and not the BDA-1 :o
I swithched back and there it was.....the BDA-1 just sounded a little better. the DAC on the Transporter is good, though..really good. But I like the BDA-1 better..it just seemed to handle the passages that were 'busier' a little better, more defined.
I could live with both...but the Transporter will continue to be fed digitally to the BDA-1.
Keith
