0 Members and 1 Guest are viewing this topic. Read 9037 times.
Previously found your web page showing different cabinets, but how is a customer to choose between them all? I assume each design has it's application/purpose/advantages.
I'll just throw in my 2 cents here regarding the P10 modified drivers: They are most definitely worth it. I recently completed a number of tweaks/modifications to my horn shoppe Horns, including adding the FE-127en drivers. Understand that I did quite a few things, including the drivers, solid, unplated copper binding posts, Chimera Labs internal speaker wire, felt treatment of the horn mouth and partial felt treatment of the compression chamber, and ballasting each speaker with 24,000 BBs, so it is hard to tell exactly what tweak did wat (except for the BBs, which I did after they were playing for a few days) and they are now far more suitable to my mostly acoustic music listening tastes, with no shout, no backwave reflection issues, a super smooth response, and no listening fatigue whatsoever. The bass is tighter, the upper mids and high end are nicely defined and very natural sounding, and all in all, I have a pair of speakers that are very much to my liking. I suppose others might find my treatments too "mellowing", but there is no apparent loss of dynamics or detail, just cleaner from bottom to top, with perhaps a very slight loss in sensitivity, but that's really not an issue for me. I'm using my Carina in UL mode (approx 3 watts) and between 12: and 2:30 on the dial is plenty for most source materials -- a touch more for discs with low recording levels, and a bit less for discs that are recorded hot, and that's playing quite loud. Which is to say, there's plenty of room left to drive the levels beyond what would be enjoyable to listen to. They also seem to play much nicer at lower levels.HTH,Jim
