0 Members and 1 Guest are viewing this topic. Read 11176 times.
Good you have it set to those null point's as they are the only null points a Technics can be set to and be corret. aa Wayner
Lets see, How many posts do you have now concerning TT's and carts? Just buy something already. I have read what your other equipment is and the Technics will out class the rest of your system. At least get the SL 1200 and an inexpensive cart. You can always get a better one later. Start collecting vinyl and get use to the process first. You may not even like it........
I like it better than the Grado Gold I have but the phonostage will make the difference I think. The Denon 103R requires a low load, I think I run it at 20 ohms? Basically the lowest my pre will go.
Quote from: BikeWNC on 10 Aug 2009, 12:02 amI like it better than the Grado Gold I have but the phonostage will make the difference I think. The Denon 103R requires a low load, I think I run it at 20 ohms? Basically the lowest my pre will go. What made you think you have to load the Denon THAT low?! The internal impedance of the Denon is 40 ohms, typically you want to load it approximately 4 times or higher than that, preferably ten times. So anything between 100 ohms to 1000 ohm will be fine. Some people plug straight into 47K and still get good result. Just experiment. But personally I think 20 ohm loading for the Denon is too low and will waste all the signal energy on driving the resistor.
