0 Members and 1 Guest are viewing this topic. Read 6101 times.
Is there a way to get songs from your existing FLAC or MP3 library on to the VortexBox without re-ripping everything? Also, what connection are you running to your receiver/DAC/etc?
Does it come with instructions to load your files and feed the SB?
I wonder how this would work on a NAS instead of putting something like freenas on it, throw this software on it.
One nice thing I think I noticed (I would have to verify that this is actually the case and wasn't an anomoly), is that you can scroll to a different position in a song. If you were wanting to play the last minute, for example, you could drag and scroll to a new position in a song. This is something that I have always found lacking with a regular Squeezebox remote (at least I didn't know how to do it if it was capable).More later...- Jim
However, you can do the same thing in SqueezeCenter via the webpage or via the remote. On your remote, you simply need to hold the next button down and it will fast forward or rewind, not just skip a song.George
