0 Members and 1 Guest are viewing this topic. Read 2559 times.
Chad,Are you still using the em7 amp? I ask because mine came with a second set of highpass inputs set at 100 Hz.Keep in mind you're going to need a tightly matched pair of fairly small value caps (at least for the em7 amp), and with higher input impedances, the number of frequency intervals covered by standard caps is going to be pretty restricted.Also, if you want to use different amps with this cable, they will have to have the same input impedance or the cutoff frequency will be different.HTH,Jim
