are all B100SST's part of the "C Series"???
0 Members and 1 Guest are viewing this topic. Read 1354 times.
Jeffr1966
« on: 3 Aug 2009, 02:22 pm »
I think the answer to this question is yes but wanted to know for sure.
My amp is serial # 314 if that makes a difference.
Any idea when this amp was manufactured???
Also, the B100 is NOT eligible for the "squared" update, only the power amps correct??
thanks in advance!
Jeff
  • The Demo is Everything!
    • http://www.bryston.com
Re: are all B100SST's part of the "C Series"???
« Reply #1 on: 3 Aug 2009, 02:55 pm »
Hi Jeff,
No there is no upgrade on the PowerPacs to SQ yet.
The B100 is not SQ as the SQ applies to the input stage of the smaller separate amplifiers which is not affected in the Integrated Amplifiers (B-60 and B100).
james
« Last Edit: 3 Aug 2009, 04:07 pm by James Tanner »
Viajero5000
« Reply #2 on: 3 Aug 2009, 03:43 pm »
James, this is also true of the 875?
« Reply #3 on: 3 Aug 2009, 04:06 pm »
Hi,
The 875 has not been changed to the SQ versions.
james
Jeffr1966
« Reply #4 on: 3 Aug 2009, 04:13 pm »
but ALL B100's are part of the C-series????
thx
Jeff
« Reply #5 on: 3 Aug 2009, 04:15 pm »
thx
Jeff
Yes all B-100's are C-Series
james
