BP25 power supply options
0 Members and 1 Guest are viewing this topic. Read 1694 times.
b5pt9
« on: 31 Jul 2009, 03:47 pm »
I bought a used BP25 from a guy who upgraded to a BP26.  It has the old AC power supply (BP-MSR??) and I'm wondering if the MPS-1 would be a worthwile and affordable upgrade?
I know I can do the full BP26 conversion for $600 + ~$1400 for the MPS-2 power supply but I don't have the coin for this right away.
This preamp will be used in place of the SP1.7 in bypass mode so I'm interested to see if it makes much of a difference.
« Last Edit: 31 Jul 2009, 11:45 pm by b5pt9 »
  • The Demo is Everything!
    • http://www.bryston.com
Re: BP25 pswer supply options
« Reply #1 on: 31 Jul 2009, 04:43 pm »
Hi,
The MPS-1 is a DC supply so it will be an upgrade from the older AC supply.
james
b5pt9
« Reply #2 on: 31 Jul 2009, 05:15 pm »
It plugs right in?  And do you have one kicking around or know of someone who does?  I would deal through Audio Ark in Edmonton.  Thanks!
werd
« Reply #3 on: 31 Jul 2009, 05:44 pm »
Hi
I got an extra mps1 power supply, with a manufacturer date 0345. I dont know if this would be compatibile or not, Probably is
« Reply #4 on: 31 Jul 2009, 05:54 pm »
Hi
CHECK WITH MIKE PICKETT ON THAT.
JAMES
b5pt9
Re: BP25 power supply options
« Reply #5 on: 31 Jul 2009, 07:15 pm »
OK I had a quick chat with Mike and he was very helpful as usual (I love this company :)).
The MPS-1 plugs directly into any BP25, even the old ones that came with the AC supply.  The MPS-1 is not necessarily plug & play with any BP20 however.
So Werd: I wonder can we make a deal for your MPS-1?  Maybe I have something you might want to trade for?  Send me a PM.
