Telefunken tubes on Cornet II
0 Members and 1 Guest are viewing this topic. Read 7524 times.
Demsy
Re: Telefunken tubes on Cornet II
« Reply #20 on: 25 Aug 2009, 04:40 am »
Hi Kel,
Sorry couldn't reply earlier, had guests staying with us. Guess from where they are, Singapore!
Yes we are practically neighbours. I go 2 or 3 times a year to Singapore and our friends also visit us often. So if it happens that I'm going to Singapore and if there is anything you need from here, audio parts related, let me know and I'll bring it for you.
D
Demsy
« Reply #21 on: 31 Aug 2009, 04:38 am »
After about 60 hours running the Cornet2 with the Telefunkens, I changed the 12AU7 with a Bugle Boy. This combination is awesome, really like it. The sound and soundstage are even better than the Telefunken 12AU7's. I think I will stick with this combination for a while, maybe another 50 hours or so before trying the Mullards 12AX7's. The rectifier tube is a Pope 5AR4/GZ34, I will try the 6106 once it arrives.
D
Kel...
« Reply #22 on: 3 Sep 2009, 12:40 pm »
Hi Demsy,
Thanks for the offer.  I can do the same for you when I visit Jakarta.  It just so happens I'm also using the Bendix 6106.  I curious to know how it compares to the Philips 5Y3G.  Do give us an update when you can.
Kel...
