Bass traps - back corners dilemma
0 Members and 1 Guest are viewing this topic. Read 1590 times.
jazzcat1
« on: 30 Jul 2009, 12:52 pm »
What is the best way to deal with the rear corners of a room if there is a door in each of the two corners? I can't do a diagonal as it would block both entrances. (one door opens into the room - hits the rear wall; the other opens out into a bathroom.) Room is 12 X 14.
bpape
    • Sensible Sound Solutions
Re: Bass traps - back corners dilemma
« Reply #1 on: 30 Jul 2009, 01:28 pm »
You can just do a panel at the corner but on the wall that doesn't have the door.  If both doors are on the rear wall, just use the end of the 2 side walls.
Bryan
Ethan Winer
  • Audio expert
« Reply #2 on: 30 Jul 2009, 04:04 pm »
The photo below shows what my partner Doug did for both rear corners of his home studio.
--Ethan
jazzcat1
« Reply #3 on: 30 Jul 2009, 05:20 pm »
Thanks for the replies. I know this won't be as good as diagonally placed but is workable. I can mount on both doors as well as the walls. I can remove the one on the entry door if I have to open it all the way.
