Ultrasonic to Rx
0 Members and 1 Guest are viewing this topic. Read 3562 times.
arthurs
Ultrasonic to Rx
« on: 29 Jul 2009, 03:46 pm »
Steve - if I am currently using Ultrasonics, could I just repace the O rings with the Rx and make the change that way?  The Rx sound like a nice little upgrade....
Herbie
    • Herbie's Audio Lab
Re: Ultrasonic to Rx
« Reply #1 on: 29 Jul 2009, 04:02 pm »
Hi, arthurs. You can purchase UltraSonic Rx Isolation Pads to replace the standard UltraSonic pads. Just slide the old pads off and push the new pads onto the titanium C-rings.
The Rx pad base material is slightly tweaked from the standard UltraSonic pad and has a groove machined into the pad to hold the O-ring in place (the O-ring is made of Kalrez formula 7075).
Standard and UltraSonic Rx Isolation Pads are interchangeable, and the titanium C-ring holding them in place is the same with both versions.
« Last Edit: 4 Aug 2009, 03:07 am by Herbie »
