FryKleaner connections for breaking in individual wires....?
0 Members and 1 Guest are viewing this topic. Read 1593 times.
gmeades
I just got my FryKleaner and the RCA to BNC/BNC to Alligator Clip adaptors today (nice they arrived at the same time)... :-)
I'm wanting to use it on individual speaker wires with banana connectors, but I don't know how to hook it up using the test leads...  I know J2 & J3 are the outputs, and that I will use the positive (red) test leads from them connected to one end of each wire, but does it make a difference which offset jack I connect to (J4 or J5), and do I connect the end that goes into J4 or J5 to the positive or negative lead on the other end...?   :scratch:
Thanks...!
mgalusha
« Reply #1 on: 28 Dec 2003, 04:50 am »
Glenn,
Connect the positive from J2 to the positive of one speaker wire, the negative of J2 to the negative of the same speaker wire and connect the other ends of the speaker cable in the same fashion to either J4 or J5, it does not matter which.
Example:
Code: [Select]
J2+ >-----------> J4+
J2- >-----------> J4-
J3+ >-----------> J5+
J3- >-----------> J5-
You can connect the other speaker cable in the same manner from J3 to which ever of J4/J5 you didn't use for the first cable.
Use the high gain setting and let em cook for a couple of days. Assuming you can live without them that long...  :lol:
Mike G.
gmeades
« Reply #2 on: 28 Dec 2003, 12:34 pm »
Thanks, Mike...!
that makes sense....  :idea:
Glenn
