Sonicap Platnium Bypass Caps
0 Members and 1 Guest are viewing this topic. Read 2751 times.
Ron
« on: 27 Jul 2009, 12:18 pm »
  The standard speaker kits that Danny provides come with high quality Erse poly caps bypassed with Gen. 2 Sonicaps.As an upgrade option,Danny offers the Sonicap Gen. 1 caps which can be upgraded even more with Sonicap Platnium bypass caps. I know the Gen. 1 caps bypassed with the platniums works very well. My question is how much of a sonic improvement would be achieved in bypassing the Erse poly cap with the Sonicap Platnium in lieu of the Gen 2 cap?
Danny Richie
Re: Sonicap Platnium Bypass Caps
« Reply #1 on: 27 Jul 2009, 02:48 pm »
It certainly would make an improvement, but for the money spent, I'd first upgrade the main cap.
Ron
« Reply #2 on: 27 Jul 2009, 07:42 pm »
 Thanks Danny for your reply. The reason I asked the question is because my current AV-1's with the Erse poly caps and Gen. 2 Sonicap bypass caps sound really good. I was just wondering if the Platnium bypass caps would make them sound even better. I take it from your reply that the platnium bypass caps would definitely be better, but not enough to justify the high cost to use with the much cheaper Erse caps. I do plan to go with the Gen. 1 Sonicaps and platnium bypass option the next time I build a pair of your Neo 2x's which should be in the near future.
corndog71
  • Some people call me Rob.
« Reply #3 on: 29 Jul 2009, 01:17 am »
Hey Danny,
do the platinums come in higher voltages like 600vdc?
Danny Richie
« Reply #4 on: 29 Jul 2009, 01:47 am »
I believe they are rated at 400 VDC.
corndog71
« Reply #5 on: 29 Jul 2009, 02:59 am »
That's a bummer.  I was kinda hoping I could use them in some tube gear.
cujobob
« Reply #6 on: 29 Jul 2009, 03:11 am »
I thought Gary Dodd did use platinums in some of his gear?
Edit:  From the DoddAudio website...
"As always Sonicap Platinums are available to upgrade the amps" for the Dodd 120 watters
corndog71
« Reply #7 on: 29 Jul 2009, 11:50 am »
well, I'm sure it depends on the application.  For some tube circuits 400v is fine but for others it's not enough.  I could use them in my preamp but not my amp.
