0 Members and 1 Guest are viewing this topic. Read 5673 times.
. . . This would mean that you have nulls in the direction of both the rear and side walls. I don't know whether there would some acoustic loading inside the "L" corner that would invalidate this simple analysis, but I am guessing that the nulls to the rear and side would reduce excitation of room modes in both of those directions. Moreover, the front lobe is angled in towards the listener so increasing the direct/reverberant ratio.JohnR
The Null(s) would NOT be oriented as you indicate.
There can only be one null plane. It would form approximately as if you were to draw an imaginary third side (dashed line, if you like) to complete a triangle.
. . . On the null plane question, Linkwitz does show that moving the dipole source away from the center of an H does create nulls at angles - http://www.linkwitzlab.com/frontiers.htm#L. (Item 2 in the fifth figure.)
This is the overall schematic of my planned project (one channel). I won't go into a lot of detail just now - but feel free to ask if you are curious about anything. Overall my goals in sound reproduction are, I think, quite similar to those of JoshK. The approach I have ended up with is different, though.
