Rega Turntables
0 Members and 1 Guest are viewing this topic. Read 6701 times.
Herbie
    • Herbie's Audio Lab
Rega Turntables
« on: 26 Jul 2009, 02:29 am »
Hundreds of Rega owners have upgraded to Herbie's Way Excellent and Way Excellent II Turntable Mats.
Most are using the standard, full-size 2mm-thick version. Though 2mm is slightly thinner than the stock Rega felt mat, users have found that with the Way Excellent Turntable Mat, a very slight downward angle of the cartridge is beneficial, providing "way excellent" results.
Herbie's Audio Lab has recently introduced, however, a new 2.4mm-thick Way Excellent II Turntable Mat specifically for Rega turntables that matches the thickness of the stock felt mat. Because most Rega turntables do not provide for VTA/tonearm height adjustment, matching the original mat's thickness provides for accomodation with the manufacturer's parameters.
Rega P9: This ceramic-platter table uses a thinner mat, about 1.5mm thick, and Herbie's grungebuster Turntable Mat (1.6mm) is a perfect upgrade. The grungebuster Turntable Mat really brings out the best potential with this fine table.
Feet: Though fewer of our Rega customers have upgraded the turntable's feet, Herbie's Iso-Cup w/Lampblack Ball has proven to be a superior upgrade, adding  even more excellence to Rega's fine performance. As Richard Makarewicz reported:
"Under my Rega P9, the Iso-Cups made quite a difference, which surprised me given the anti-resonance work Rega put into their P9 plinth. There was also a greater sense of presence, or 'aliveness' to the music, and bass lines in particular were much more easily followed, occupying a more specifically defined space in the mix. A very worthwhile upgrade."
More info at our website:
Turntable Mats
Steve Herbelin
Herbie's Audio Lab
« Last Edit: 23 Aug 2010, 01:50 am by Herbie »
cujobob
Re: Rega Turntables
« Reply #1 on: 27 Jul 2009, 04:27 am »
Link is broken...missing extension  ( .htm )
Herbie
Re: Rega Turntables
« Reply #2 on: 27 Jul 2009, 04:38 am »
Fixed. Thank you much!  :oops:
