0 Members and 1 Guest are viewing this topic. Read 2822 times.
I don't agree with your findings, but I think I know what you are experiencing. What are you using to drive the STs? Dome or RT version of the STs.I don't have an answer for you, but I am curious if I can help "fix" your issue. If not, I'll share what I've found regarding a very similar situation that I had. Notice the word "had".
Quote from: TJHUB on 25 Jul 2009, 01:52 pmI don't agree with your findings, but I think I know what you are experiencing. What are you using to drive the STs? Dome or RT version of the STs.I don't have an answer for you, but I am curious if I can help "fix" your issue. If not, I'll share what I've found regarding a very similar situation that I had. Notice the word "had". Hi TJHUB, I'm using the Dome version of the SongTower's and I'm driving them with a Marantz 7002.
What CD player are you using and what kind of interconnects to you have between it and the Marantz?And just for clarification, you said you swapped cables, what did you exactly swap?
I haven't heard that effect either. Is your left speaker located more in a corner? Sometimes if the speakers are not located symetrically to room bounderies, one speaker can reinforce certain frequencies. Maybe that is what is happening with your left speaker and reinforcing the vocal frequency range.Good luck.Tom
You may have to balance the left and right channel on certain songs. A integrated amp I previously owned was sending less information to the left speaker than the right one during low listening levels. It was driving me crazy but it turn out to be the amp rather than the cd player. Does this happen only at low level listening or is it present at all levels?Good luck.
Quote from: revrob on 25 Jul 2009, 03:21 pmYou may have to balance the left and right channel on certain songs. A integrated amp I previously owned was sending less information to the left speaker than the right one during low listening levels. It was driving me crazy but it turn out to be the amp rather than the cd player. Does this happen only at low level listening or is it present at all levels?Good luck.I've only noticed it at low listening levels, but I haven't been able to crank it up much lately.
Hopefully you've got the issue nipped in the bud, but in case you didn't, have you used an SPL meter to ensure both speakers are level matched? If one is even 0.5 dB louder it can cause issues....
The 0W2 tweeters are matched at the factory. The Seas woofs are not, but the quality control is excellent. Besides, there are two per side, so any tiny deviations are more likely to even out. In any event, I would bet what's left of my IRA that there's not an issue with driver matching.
