0 Members and 1 Guest are viewing this topic. Read 4149 times.
The question is where to start with the panels.
Actually, if you make the spanning panel 6" thick and 2' wide, it takes the same amount of material as a triangular chunk of the same height.The 6" panel straddling will reach slightly deeper but will also take up a lot more space in the room. The rear of the spanning panel starts where the chunks would stop.Bryan
