WTB - Vintage Audio Technica Radial Arm LP Cleaner 'Audiocleanica AT 6002'
0 Members and 1 Guest are viewing this topic. Read 3312 times.
ideasource
Dear All
I lost my gear in my divorce and I'm trying to find some vintage gear I once had.
I'm looking for this Audio Technica/Japan radial arm LP cleaner called the 'Audiocleanica AT 6002', also marketied by AT-USA as part of the PDQ record cleaning kit.
It looks much like the venerable Watts Dust Bug or similar Decca cleaner. It features a bright chrome metal/plastic arm and base, red velvet plush cylinder to pick up dust and a carbon fibre tip to drain static.
I found it did a credible job to keep dust out of the grooves since I tend to play without the awkward dustcover.
If anyone has this new, knows of a retailer who has it, or has a used one in good condition, PLEASE let me know directly at: [email protected].
Thanks in advance.
Michael
chosenhandle
I am sure your ex can't live without that gem. I think we should start a support group for guys who lost great stuff in divorces. My ex made a point of giving away or throwing away stuff she knew I wanted.
Wish you the best of luck. I assume you have a saved search on ebay.....
