Quickie Groneberg TS Premium speaker & IC cable review
0 Members and 1 Guest are viewing this topic. Read 2922 times.
cookie
« Reply #1 on: 27 Dec 2003, 02:44 pm »
I'm using Zu Wax and Zu Varial IC and I'm really interested with your review and comments.  I did order the Groneberg Quattro Reference IC and speaker cables.  Any idea how it may compare with Zu products?
I wish Klaus would consider selling Groneberg TS Premium.  The Euro price on their web site is too expensive.  I think Klaus can get a better price for us.   For those who ordered Mono Extreme, they may want to get a version with TS Premium as standard cable internally if it's really that good.
Klaus, do you plan to sell Groneberg TS Premium IC and speaker cable?
byteme
« Reply #2 on: 28 Dec 2003, 03:33 am »
Cookie,
I've never heard the Quattro cables, however, if you have Odyssey gear from what others have said there is a ton of synergy there.  You'd have to ask Klaus about the availability of TS Premium and based on the thickness of the TS Premium I don't know if there would be room in any amp case to use this as internal wiring!
klaus@odyssey
« Reply #3 on: 1 Feb 2004, 07:49 am »
Well,  I do sell the TS's,  o course.  The cost is not quite twice that of the Quattro, and yes,  it is better, of course.  But then again,  as with all cables,  better to what ???  and in what synergistic issues ???
IMO  the Quattro just kicks ass for the $ / performance ratio in the majority of systems,
Klaus
And yah, yah, yah,  I know,  I'll have to update the site.
