0 Members and 1 Guest are viewing this topic. Read 13848 times.
Thanks everyone for your help.These Abby's are well broken in, they are several years old, I am the 3rd owner.I would like to try those tweaks, the phase plug sounds interesting as well as the doping of the baskets, the shiny glue on the cones, that scares me a bit, but what do I know?Mike
Hey, now I know you may not want to hack up your Fostex drivers right away but there is a tweak you can do that will help (dramatically) with that midrange megaphonish sound they can sometimes take on. One of the guys out there (I think he is at DIY Audio) sells a phase plug for the Fostex. It works pretty darned well. One of the local guys down here uses it on his. All you do is take a razor knife and cut off the dust cap (not the whizzer). The phase plug has a magnet in it and it sticks to the motor of the driver. The tweak takes a steady hand and about ten minutes. The phase plug sells for like $50-$75 bucks (I could be wrong on the price).
[(you can also use regular yellow glue diluted lets say 50/50 with water)
That would be me. dave
I do have both drivers and I agree with you before the mod I liked the 165 better. Since the decware mod I prefer the 166. Once again my room my system.
