Picked up a Titan XL to be used with my emerald Xl's..thoughts?
0 Members and 1 Guest are viewing this topic. Read 1427 times.
starkiller
would like some input on level settings and such when setting up the tital xl with the emerald xl's.
Niteshade
    • Niteshade Audio
Just set it according to taste.  :D
It all depends on room size and speaker placement.
Mike Dzurko
Yep, every system is different. Just follow the quick setup in the manual to get rolling and understand what the controls do. As you listen, you'll start to fine tune until you get it just right.
rockadanny
Use a Radio Shack SPL meter to do it. Do not rely only on your ears.
starkiller
sounds good everyone, this titan is huge!  this was the kit and the guy built the vertical version :)
