good way to clean tube pins
0 Members and 1 Guest are viewing this topic. Read 1623 times.
PatOMalley
  • This text is personal
    • http://home.comcast.net/~omaille/audio/home.html
« on: 14 Jul 2009, 12:21 am »
A good way to clean tube/valve pins is Magic Eraser. Shove the pins down into the cleaning pad over and over. Give it a twist. I used a jewelers loupe to look at the job it did and the pins were shining when I finished.
richidoo
Re: good way to clean tube pins
« Reply #1 on: 14 Jul 2009, 01:48 am »
Good idea. Those things are amazing.
http://www.mrclean.com/en_US/magic-eraser.do
tubesforever
« Reply #2 on: 14 Jul 2009, 07:35 am »
They do a great job cleaning crusty stuff off diamond stylus as well.
With this hobby ME seems like a no brainer.  I use it for dozens on things.  Great post by the way.  I have been using 1200 grit wet dry sandpaper.  I think ME would be much gentler on the tungsten or nickle pins.
