rackmounting 3B-SST2 and 4B-ST; BDA-1 upsampling light
0 Members and 1 Guest are viewing this topic. Read 1098 times.
dubkarma
  • "God made man because he loves stories." - Canetti
Hi James and other knowledgeable Bryston users. . .
Dumb questions, perhaps, but. . .
I'm using a 4B-ST and a 3B-SST2 (both with 19" faceplates and rackmount holes) as the MF and HF amps in an active tri-amped system. I would like to rackmount them. But can I do so simply mounting them by the faceplates, or do they require brackets at the rear as well (as is the case with my MC2 power amp)?
An unrelated question: When I engage upsampling on my BDA-1 a yellow light turns on. From the manual I understood (or misunderstood) that this was supposed to be a green light. Am I just confused or is there some issue with my BDA-1?
Thanks in advance for the clarifications.
Joel Tatelman.
  • The Demo is Everything!
    • http://www.bryston.com
Re: rackmounting 3B-SST2 and 4B-ST; BDA-1 upsampling light
« Reply #1 on: 12 Jul 2009, 04:33 pm »
Hi Joel,
The light will be amber (yellow) or green depending on the incoming bit stream - so no issue with your BDA-1
Yes you can rack mount the 3B and 4B just with the faceplates - no bracket required.
james
dubkarma
« Reply #2 on: 12 Jul 2009, 05:56 pm »
James,
Thanks very much for the quick and informative reply!
Joel.
