0 Members and 1 Guest are viewing this topic. Read 2016 times.
Otis
« on: 11 Jul 2009, 02:50 pm »
« Last Edit: 2 Feb 2011, 07:00 pm by Otis »
avahifi
    • http://www.avahifi.com
Re: Thinking about a MK IV. mono amp
« Reply #1 on: 11 Jul 2009, 09:09 pm »
The Mk IV is indeed a single channel St-70.  Unfortunately it has half the space available for the circuit board, not nearly enough room for the new Ultimate audio circuits and power supply.  Also demand for upgrading the MK IV is at about 1 percent of that for the ST-70, not enough to make it economical to design new circuit boards to try and shoe horn into the space available.
Frank Van Alstine
Listens2tubes
« Reply #2 on: 14 Jul 2009, 02:56 am »
Don't forget to add that if a MkIII board was thought worthwhile the MkIV could share it with only some parts changes. :duh: Oops! Did I mention one of Frank's least favorite amps? :evil:
Tone Depth
  • Music Lover
    • SRLPE Wheel Works
« Reply #3 on: 18 Jul 2009, 02:48 am »
Don't forget a U70 can be bridged using an AVA Inverter Bridge into a mono amp, similar to bridging two of them into a stereo pair:
http://www.avahifi.com/root/equipment/bridge/bridge_wiring_dual_mono.htm
