FS: Zu Audio Oxyfuel Audio Cable 1 meter $50 O.B.O
0 Members and 1 Guest are viewing this topic. Read 596 times.
jlathe
The Oxyfuel really delivers on our hype of high value. It is a pure, ripped down coax design featuring a large diameter, pure copper outer conducting path for center pin, microcellular foamed PE dielectric with a bonded high conductance aluminum shield. If you are looking for an interconnect that really will improve the fidelity of your system and don't need fancy hi-fi salesmanship, slick packaging or foo dust the Oxyfuel is your cable!
Termination is 100% solderless and features gold plated RCA-type connectors.
Looking for get $50, but willing to negotiate.
Technical Specs
    * 2.5 GHz bandwidth
    * 100% low magnitude shielding
    * no inter-strand contact noise
    * micro-cell foam dielectric
    * deposited tubular Cu alloy center conductor
    * solderless termination
    * made in USA
    * high tolerance (>0.1% )
