**SOLD**Electrocompaniet EC4.5 balanced line preamp - sweet
0 Members and 1 Guest are viewing this topic. Read 5057 times.
Big Red Machine
Retail was $2000.  Asking $800 shipped to lower 48.  Others need to kick in some more.
Have remote, stock PC, and manual.  Matches my AW220 amp with similar glass face.
Has balanced in and out as well as RCA in and out with a set of phase inverting jacks as well.  On/off, volume, balance, and input select on front panel.
Technical Specifications EC4.5 :
Preamplifier section
Single ended operation (gain) 0 dB
Balanced operation (gain) 6 dB
Input impedance 50 kOhm
THD single ended (1.5 V output) 10 V RMS
Channel separation (1 V output, 1 kHz) > 90 dB
Output impedance 100 Ohm
Max. output Single ended 8 V RMS
Max output Balanced 16 V RMS
Output noise 400 Hz - 30 kHz input shorted
Single ended : 6 ?V
Balanced : 11 ?V
Power consumption (no load or signal) 15 W
Dimensions
Width 483 mm / 19 inches
Depth 240 mm / 9.5 inches
Height 70 mm / 2.8 inches
Weight 5 kg. / 11 lbs.
« Last Edit: 13 Jul 2009, 11:39 pm by Big Red Machine »
Big Red Machine
Re: Electrocompaniet EC4.5 balanced line preamp - sweet
« Reply #1 on: 7 Jul 2009, 12:40 pm »
Big Red Machine
« Reply #2 on: 7 Jul 2009, 12:50 pm »
I added my email to my profile since I cannot use the PM system.  It crashes every time I try to use it.
Big Red Machine
« Reply #3 on: 9 Jul 2009, 02:10 am »
bump it
Big Red Machine
« Reply #4 on: 11 Jul 2009, 03:33 pm »
bump
Big Red Machine
« Reply #5 on: 12 Jul 2009, 11:05 pm »
want both the preamp and the amp, let's talk!
I have back my Bella Purity pre so I don;t need this EC unit any longer :(
