Dual 1228 Turntable - Stock
0 Members and 1 Guest are viewing this topic. Read 1272 times.
whell
« on: 4 Jul 2009, 03:19 pm »
This one has been checked out, played and lubed. Its running nice and quiet, and the speed from the idler wheel is nice and stable. Speed strobe works well. The stock interconnects will be included with this table. The nice thing about the 1228 is that you can swap out your cables of choice. There are RCA's right on the circuit board, so no soldering required. Multi play spindle included.
No cartridge is included, but I have a choice of a cart or two that I could mount for you for additional cost.
The only issues: though the table is fully auto, you'll need to use it as a semi auto, or adjust the mechanism. The auto start doesn't drop the needle dead on into the lead in groove. Also, cuing is a bit too fast, and may need to have the fluid replenished.
$70 or best offer. Cartridge extra if desired. No shipping please. I live in Metro Detroit.  I do travel to Ohio frequently for work, so possibly I could meet someone while on a work trip.
