Balanced Isabellina
0 Members and 1 Guest are viewing this topic. Read 2135 times.
KingStyles
Balanced Isabellina
« on: 3 Jul 2009, 05:45 am »
I am wondering if you ever considered making a balanced version of the isabellina. I realize it would probably need two isabellina dac boards in it to get a fullly balnced output which would raise the price significantly. There just isnt any really good nos dacs out there and the oversampling ones are only a handful. It seems to be a rising awareness about balanced setups and was curious if you are considering building one in the future.
Vinnie R.
    • http://www.vinnierossi.com
Re: Balanced Isabellina
« Reply #1 on: 3 Jul 2009, 07:41 pm »
Hi KingStyles,
Unless you have very long interconnects that are prone to to picking up EMI/RFI, I don't see the the benefit and prefer not to add the extra complexity.  I suppose there are a lot of differing opinions about this...
So to answer your question, we have no plans to offer balanced-outputs on the Isabellina.
Best regards,
Vinnie
Alwayswantmore
« Reply #2 on: 27 Sep 2009, 03:00 am »
My entire rig was balanced about 4 years ago (Ayre, Wadia, Vandersteen crossover, expensive ICs, bi-wired speakers, etc.). I was pretty convinced balanced was best at the time. Now I've gone minimalist with all RWA and single drivers with a sub. Isabella w/DAC, 30.2 straight power amp, Apple macbook w/usb, Anticable speaker wire.
I can't say that RWA is hands down winner in every aspect of sound, but I can say it is much more natural sounding, and more satisfying to listen to.
Kent
