Neko Audio D100 - Enjoy the Music.com Review
0 Members and 1 Guest are viewing this topic. Read 2039 times.
NekoAudio
    • Neko Audio LLC
« on: 1 Jul 2009, 01:24 am »
Enjoy the Music.com has published a review of the Neko Audio D100 in their July 2009 issue.
"clean and natural."
- Nels Ferre, Enjoy the Music.com, July 2009
Read the full review.
The D100 has also received rave reviews from Affordable$$Audio, TONEAudio Magazine, and Positive Feedback Online.
For more information, including customer reviews, visit Neko Audio.
« Last Edit: 22 Jul 2009, 03:32 pm by NekoAudio »
Big Red Machine
Re: Neko Audio D100 - Enjoy the Music.com Review
« Reply #1 on: 1 Jul 2009, 01:58 am »
I emailed (while investigating possible DAC choices) an Audiogon customer who bought one of these and he was very happy with it.  I can't afford one myself right now, but maybe someday I can try one.
cryoparts
« Reply #2 on: 1 Jul 2009, 02:31 am »
FWIW--I met Wes at CanJam (I loaned him a coax cable) and he is a heck of nice guy!
Peace,
Lee
NekoAudio
    • Neko Audio LLC
« Reply #3 on: 4 Oct 2009, 06:23 pm »
Oh, hey Lee! I never saw you replied to this post. It was really great meeting you too and thanks again for letting me borrow the cable! :)
Charles Calkins
« Reply #4 on: 4 Oct 2009, 10:39 pm »
What's the difference between the D-100 and the MK-2 besides cost?
                             Cheers
                             Charlie
jmc207
« Reply #5 on: 4 Oct 2009, 11:14 pm »
From www.nekoaudio.com:
"The D100 Mk2 features new Jensen transformers that provide an additional 6dB of gain while maintaining the same sonic characteristic of the D100."
Charles Calkins
« Reply #6 on: 4 Oct 2009, 11:44 pm »
Thank you.
                           Cheers
                           Charlie
jmc207
« Reply #7 on: 5 Oct 2009, 12:47 am »
NP, I had missed this bit of info as well when I first saw the Mk2 version listed. Still not exactly sure what the final output voltage is with the new transformers, but they should help get in more in line with most other DACs. A very interesting and tempting DAC.
NekoAudio
    • Neko Audio LLC
« Reply #8 on: 5 Oct 2009, 05:32 am »
The original D100 has an output voltage of 1V. The Mk2 has an output voltage of 2V, which is the typical RCA output voltage.
One thing to consider is that your amplifier input sensitivity may be around 1V, in which case the additional gain wouldn't be of use to you unless you really like to push your amp past its operational range. Which is likely to dramatically raise THD.
Even if your amplifier's input sensitivity is 2V or higher, THD may be much higher at that voltage. My reference amp's THD+N starts to dramatically increase somewhere around 1.5V.
Of course, your pre-amp will be used to increase or decrease the DAC's signal voltage anyway.
