Demo sale item: A beautiful sub-woofer!
0 Members and 1 Guest are viewing this topic. Read 4946 times.
Danny Richie
« on: 30 Jun 2009, 03:05 pm »
SOLD
This has been my personal subwoofer but due to the fact that many of the speakers I listen to are full range, or I am listening to or testing a new speaker, I hardly ever use it.
This uses a pair of our SW-12B woofers and matching PR-12A passive radiators (mounted on the back side). It's -3db down point is 20Hz.
The box is well braced and has double wall thickness on each end. It was then lined with Blackhole 5. It is solid as a rock and produces no resonances of its own. I am guessing the weight to be around 180 pounds.
The veneer is a rather expensive Mappa Burl with figuring. It was oil rubbed then multiple coats of polyurethane. It was wet sanded with 600 grit between coats and topped of by wet sanding it with 1200 grit then polished with 3M polishing compound. The ends are painted in a flat Black to match the drivers.
You can see the depth of the clear coat in this pic.
It has the Apex Sr. amp from Apex Jr: http://www.apexjr.com/Apexsenior.htm
This will deliver 350 watts of power into this impedance load, and is just right for the pair.
This sub is really clean sounding and looks great. I am pricing it to sell. $900 and it's yours. This does not include shipping.
« Last Edit: 8 Mar 2010, 02:23 am by Danny »
Danny Richie
Re: Demo sale item number 1
« Reply #1 on: 10 Sep 2009, 07:52 pm »
Surprisingly, I still have this beauty.
Ryan45872
« Reply #2 on: 2 Feb 2010, 12:29 am »
Danny
Is this sub still available? What are the dimensions?
Ryan
« Last Edit: 21 Feb 2010, 01:18 am by Ryan45872 »
Danny Richie
« Reply #3 on: 2 Feb 2010, 12:34 am »
Yep, and I am surprised that no one jumped all over it. It is absolutely gorgeous.
It is 33.25" wide, 23.5" deep, and 16.5" tall.
persisting1
« Reply #4 on: 18 Feb 2010, 01:04 am »
I can't believe this hasn't sold.  If I had the room for this sub, I'd buy it.
Danny Richie
« Reply #5 on: 18 Feb 2010, 01:27 am »
I am actually surprised this one didn't go fast. It is absolutely gorgeous.
Yes, I still have it.
Danny Richie
Re: Demo sale item: A beautiful sub-woofer!
« Reply #6 on: 24 Feb 2010, 05:25 pm »
Okay, I'll take $800 for it if someone comes and picks it up. I hate to let it go for that, but I am just not using it.
roscoeiii
« Reply #7 on: 24 Feb 2010, 06:23 pm »
Could you cut it in half so I could have dual subs? :lol:
pmctexas
« Reply #8 on: 24 Feb 2010, 06:47 pm »
Danny - I'm interested if it is still available when I come up to visit...
paul
Hank
« Reply #9 on: 25 Feb 2010, 06:47 pm »
No wonder it looks gorgeous:  Danny used the correct brand of rubbing compound!   :thumb:
jtwrace
    • TIPP YouTube Channel
« Reply #10 on: 25 Feb 2010, 06:50 pm »
Guess that means you work for 3M
