8th Nerve sub recommendation
0 Members and 1 Guest are viewing this topic. Read 1991 times.
8thnerve
« on: 23 Dec 2003, 03:02 pm »
Von Schweikert VRS/1
« Reply #1 on: 24 Dec 2003, 02:33 am »
Here's the link:  http://www.vonschweikert.com/vrs1.html
What else can you tell us?
Cost?
Peak volume?
Size?
Weight?
Why do you recommend this one in particular?
Thanks for the heads up.
8thnerve
« Reply #2 on: 30 Dec 2003, 06:17 pm »
Cost?
$1495
Peak volume?
A lot.  I can push about 106 db in a 24x22 room with just one.
Size?
SMALL.  11x11x14
Weight?
50 lbs. !!
Of all the active subs I have heard, I have only ever really liked the REL subs and now this one.  And that includes REAL EXPENSIVE ones as well.  Most just don't integrate with music well.  This one is fast, deep and affordable.  Just wanted to make sure it didn't get left out since this one doesn't get talked about much, but is a great piece.
Cens
« Reply #3 on: 30 Dec 2003, 06:31 pm »
Have you compared the VS sub with the REL Strata III in particular?  I have a Strata III and like it, but like the smaller size of the VS.  (I also like VS speakers, at least the pair of VR1s that I use in my 2-channel HT.)
Thanks for any input.
Chris
