0 Members and 1 Guest are viewing this topic. Read 8236 times.
It's hard to pass up free.The 4 lb. stuff is nasty and i didn't use it. All I used was the 8 lb. stuff and it's not bad to work with. In my area the 703 is just a few cents more per ft. than the rock wool.
I've been doing research about acoustic treatment in the room that I'll be using for a music room. I'm thinking about using OC703 Superchunk for the corner bass trap, I assume that the Superchunk with the 34" front face will be more efficent than the smaller chunk with the 24" front face. I assume that using hot glue to hold each of the wedges together would be good.Bass Trap wedges work well in the corners, so I assume that they would help out if some were placed at some even smaller ones (maybe 10"x10"x14") at the wall floor junctions. I'm also thinking about placing OC703 2'x4'x2" sheets at the points where I can see a reflection of the Magnepan 3.6Rs in a mirror would be good.Would it be benefitual if I were to add some diffusers to the room as well. If so, would it be better to place them behind the maggies since they are a Dipole speaker?
The OC 703 was developed to be used in machine room walls to help with the high pitch of machines and equipment.
