Help with noise....
0 Members and 1 Guest are viewing this topic. Read 3386 times.
low.pfile
Re: Help with noise....
« Reply #20 on: 30 Jun 2009, 10:50 pm »
So what kind of vaccum do I need to use with the KAB EV-1??
I have a dyson home vacuum cleaner, will that work?
Not sure if mine is optimal but it's 4HP and works well with my KAB ev1. On the vac hose there is a little twist valve to bleed off pressure if needed-but I don't : Metro Vac and Blo [info] Depending on the hose of the Dyson, you may be able to use that. My Dyson has a wand type manual hose which would require an adapter, not sure how common that is on Dysons.
kingdeezie
« Reply #21 on: 30 Jun 2009, 11:34 pm »
Mine also had a wand, but if you press the gray tabs where it connects to the hose, you can remove it leaving just the hose...
This has me thinking its usable.
TheChairGuy
« Reply #22 on: 1 Jul 2009, 01:59 am »
In the end it looks like 180 to get it shipped here to me; that's not too bad if I can use the vacuum I have now.
Better money rarely spent on vinyl playback.  Better than equivalent outlay in a 'better' deck or phono preamp.
Perhaps the only thing equaling it in improving your enjoyment of the medium is a really decent maple or granite (or whatever works) sub-base/shelf and some feet that sound best to you.
Aside from that, the RCM is King of Value in Vinyland :thumb:
John
Miney
  • Free your mind... and your ass will follow
« Reply #23 on: 1 Jul 2009, 03:25 am »
Reading and replying to this thread motivated me to get caught up on cleaning - but the old dirt devil hand vac went up and died! :duh:
Turned out to be a good thing tho...  hooked up the Kenmore Upright, and not only does it have better suction, it's also was much quieter.  Ran it on low - definitely don't need all the suction it offers and would never use the shop vac.
