0 Members and 1 Guest are viewing this topic. Read 22810 times.
I figured some one would ask that question. The answer is yes, it is a type of SMPS. It is not a typical SMPS, what I have done is I found a way to improve effiency to well over 98%, and I aint saying how I achieved it. That is the magic part of this power supply and it will be protected. aaGary
....98% efficiency is not that big of a deal....
Hello Gary,Nice amp! What is the minimum hum level at the output? Also what is the input sensitivity for full rated power and input impedance?I have 100 dB speakers and hum is its enemy.regards,Abe
Quote from: amandarae on 28 Jun 2009, 01:14 amHello Gary,Nice amp! What is the minimum hum level at the output? Also what is the input sensitivity for full rated power and input impedance?I have 100 dB speakers and hum is its enemy.regards,AbeHey Bro! This one has definitely got your name on it! aa aa aa aa
I guess I just care about sound quality rather than efficiency. Class A amps have never been about efficiency. In order to get 15W from a pair of EL84, I suspect that we are stepping onto Class AB push pull territory here.
