How to measure bias?
0 Members and 1 Guest are viewing this topic. Read 2144 times.
rockadanny
« on: 27 Jun 2009, 12:17 am »
I am considering trying a pair of tube mono-blocs which have pots for biasing and test points for measuring. I assume I'll need a meter to do the measuring? What meter should I get (good but inexpensive)?
Niteshade
    • Niteshade Audio
Re: How to measure bias?
« Reply #1 on: 27 Jun 2009, 12:24 am »
You should consider a digital DMM with an auto ranging function. As far as the voltage, ask the previous owner or contact the factory.
Note: If amp seems to run too hot at recommended bias, tune for best sound and less heat.
Example DMM: http://www.sears.com/shc/s/p_10153_12605_03482139000P?keyword=multimeter
rockadanny
« Reply #2 on: 27 Jun 2009, 12:48 am »
Thanks Blair!
