Good-bye to RB300 interconnects......................................
0 Members and 1 Guest are viewing this topic. Read 1594 times.
Wayner
The more I get involved in the Rega world, the more confused I become. Many designs seem to be a contradiction in goals. Today I found myself fixing the stock interconnects out of my RB300 tonearm (mounted on ARMod), and decided enough is enough.
The interconnects would make noise when you moved them, occasionally have hum and constantly had problems with the interconnects. The real problem is the wire. I dissected the cable and the shield is a simple wire wrap around the  coated center conductor. Construction was like the Recoton plugs you use to buy for 99 cents at the local audio salon.
Not that these cables are bad, but they should at least have adequite shielding. So I cut off all but about 3 inches, made a nice copper RCA jack mounting plate and soldered the wires to that assembly.
This allows me to use the cable of my choice, which was the Bluejeans LC-1 at 1.5 meter. Gone are the crackly sounds, the hum the other imbellishments. Here is the ultra nice and quite background. I can turn the preamp all the way up an hear nothing but the residual of the system. No hum.
No, I'm not suggesting that everyone go out and chop off their interconnect cords. But it really makes me think that Rega makes some bad design choices in their turntables, the interconnect is one of them. If I were to make and sell tables, they would only have RCA jacks for termination.
The arm is a work of art. Anyway, I'm going to listen to a bunch of vinyl today as it is hotter then hell out again and I have all my chores done.
Wayner aa
Listens2tubes
I'm with you on this one Wayne. I rewired my RB250 with Cardas from clips to Copper Bullet RCA's. and am happy with the results when all is positioned just right, but, I have considered exactly what you've done. Meanwhile my Technics SL-D1 had captured cable interconnects until I clayed the plinth and eliminated the cable and mini-board the tonearm wires were soldered. Then added a pair of RCA jacks where the old wire emeged from the base. These two improvements make it a fantastic little brother to the SL-1200. 8)
TRM
I've often thought about having someone put some nice wire on my P1. Not in the same class as your table obviously but I can't help but wonder about the cheap wires coming off of there
Wayner
I'm considering cutting off the cables on my Technics SL-1200MKII as well. I've made some DIY cables out of solid wire and I'm liking it lots. aa
I'm not interested in replacing the tonearm cable at this time, but I might put some jacks on the top part of the plinth. I think it would be real easy, I've been inside before. I also have a Technics SL-Q2 out in the garage that might also get "nutered".
Wayner :)
topround
I replaced my Rega arm with a SME and never looked backed :thumb:
Go the whole hog
you will be impressed
Mike
