Who makes SEALED subwoofers?
0 Members and 1 Guest are viewing this topic. Read 1778 times.
IanATC
« on: 23 Dec 2003, 08:17 am »
I noticed that most subs are ported, a few use passive radiators.  Since my speakers are sealed, I'd like to augment them with a sealed sub for best results.
-Other than the PAINFULLY  expensive ATC, who makes sealed subs :?:
bubba966
« Reply #1 on: 23 Dec 2003, 08:24 am »
M&K makes a few different sealed subs. Have a pair of M&K V-125's that I'm quite happy with.
Sa-dono
« Reply #2 on: 23 Dec 2003, 08:39 am »
Onix, Adire, and ACI all make affordable, musical, sealed subs.
StevieM
« Reply #3 on: 23 Dec 2003, 08:47 am »
Hi Ian
I have recently completed building the SW2 kit from IPL acoustics and am very happy with it. Look at http://www.iplacoustics.co.uk/ipl_acoustics_kits_for_hi.htm they also do a larger one.
It is a fully sealed design, has a good range of adjustments and assembly was very easy.
If you live within driving distance of Southampton you are welcome to come and have a look/listen.
A friend has a Rel Strata which is very good, and is a sealed box, though it cost rather more than my IPL kit.
jackman
« Reply #4 on: 23 Dec 2003, 12:11 pm »
Check out the new offerings from DIYCABLES.com using the Tumult and new Adire driver, the new offering from Brian Bunge from Rutledge Audio, Adire's Rava (still a great bargain) or get some drivers, a plate amp, a flat cabinet kit from Partsexpress and roll your own!
J
Val
« Reply #5 on: 23 Dec 2003, 05:19 pm »
Acoustic Visions sells relatively affordable sealed subs with Adire Tumult (Kilimanjaro model) and my favorite Adire DPL12 (Elbrus model) drivers. I am sure a pair of either is all you'll ever need:
http://www.acoustic-visions.com/~acoustic/products/subwoofers/pre_finished/pinnacle_index.shtml">AV Pinnacle Series
rosconey
« Reply #6 on: 23 Dec 2003, 10:03 pm »
i have big sealed stand mounts -24h,10w,12d-they are sealed and there is no bad kharma between them and my vmps large :mrgreen:
pr's work nice -dont like port chuff from ported
