AIR
0 Members and 1 Guest are viewing this topic. Read 1683 times.
pardales
AIR
« on: 21 Jun 2009, 02:08 am »
Anyone have any experience with the Macbook Air, positive or negative?
Mariusz
Re: AIR
« Reply #1 on: 21 Jun 2009, 02:14 am »
Positive. (for my needs and usage)
Mariusz :)
soooowhat
Re: AIR
« Reply #2 on: 21 Jun 2009, 03:23 am »
I use a MacBook Air for work, and love it.  Just bought my daughter one as well.
Never used it for audio really.  i use a MacBook Pro to interface with Firewire DAC.
JohnR
Re: AIR
« Reply #3 on: 21 Jun 2009, 04:21 am »
I have the first generation Air and really enjoy using it. Two features I really like are the backlit keyboard and the excellent screen - easy to see even in bright light. And the light weight of course. The only "feature" I don't like is having only one USB port - sometimes I'd like to use my broadband modem and a card reader at the same time (without futzing with a bus, which would require disconnecting the modem anyway....)
However there's been some "trickle-down" to the 13" macbooks now, so I think it's a closer call than it used to be. I use mine as a portable adjunct to my desktop - I don't think I would have it as an only machine.
YMMV :)
pardales
Re: AIR
« Reply #4 on: 23 Jun 2009, 01:51 am »
Very helpful, thanks.  :thumb:
shokunin
Re: AIR
« Reply #5 on: 23 Jun 2009, 07:21 am »
I have had three airs, the Rev A 1.6/HDD, Rev. A 1.80 w/SSD and currently own Rev. B 1.86/128gb SSD.  All have been wonderful although there are limitations.  The memory is soldered on the motherboard so the max is 2GB.  Speed wise, using MSR tools my Air is almost always in a lower EIST state 600-800mhz, and spikes to 1.6 or 1.86 only when needed.  There is far more of speed difference between SSD and HDD than there is between the GHZ of the processor.  Mainly because the CPU rarely if ever sustains the 1.86ghz speed.  When I had both Rev A's, I could NOT even sustain 1.80ghz for more than a few seconds, thermal throttling kicked in and reduced the speed to 1.6ghz.  Pretty effen lame.
The Rev B's are much better in not throttling as quickly, but cooling is still an issue.  As for the HDD/SSD debate, go with the SSD, the Air's use 1.8" drives and don't use standard SATA connectors so a user-upgrade on the HDD to SSD is difficult.  Heck the Rev A used a PATA IDE "ZIF" interface, Rev B's use a SATA "LIF" interface, so trying to even find an SSD in 1.8" form factor with a LIF instead of SATA is tough.
I haven't looked into the new Rev C's, but it seems identical other than the speed bump.
