Quiet fans?
0 Members and 1 Guest are viewing this topic. Read 1745 times.
jtwrace
    • TIPP YouTube Channel
Quiet fans?
« on: 20 Jun 2009, 06:15 pm »
Has anyone found very quiet micro fans for an equipment project?  I would like to put one under each amp just so it will blow some air across it.  I have some granite platforms that are elevated off the floor and had a cutout (similar to a countertop for a sink) put in it and would like to put some fans under them for the summer months when the house is a little warmer.
If you know of some that are very quiet, please post away.
Niteshade
    • Niteshade Audio
Re: Quiet fans?
« Reply #1 on: 20 Jun 2009, 06:48 pm »
Look here: http://www.newegg.com/Product/Product.aspx?Item=N82E1683
If you could run this with about 5-8 volts DC, it would move a good deal of air and be nearly silent. Put a little 30W oil in the bearings too.
A regulated DC power supply using a LM317 would drive a couple of these very well. You could control the voltage with this IC too.
jtwrace
Re: Quiet fans?
« Reply #2 on: 20 Jun 2009, 07:00 pm »
link doesn't work.  :(  what is a LM317?
Niteshade
    • Niteshade Audio
Re: Quiet fans?
« Reply #3 on: 20 Jun 2009, 07:25 pm »
The fan is at www.newegg.com
Here is the model: MASSCOOL FD08025S1M4 80mm Case Fan
It's a 12V computer case fan. When the bearings have a good lube on the, like 30W, it will run very,very quiet with around 5-8v DC applied to it. A LM-317 is a variable voltage regulator 3 pin I.C. Makes an excellent fan controller and requires a heat sink. You could also use something like one of those multi-voltage power cubes to run it.
Photon46
Re: Quiet fans?
« Reply #4 on: 20 Jun 2009, 11:03 pm »
I've had good luck with 80mm fans I've bought from www.quietpc.com.  They don't sell the exact model I've bought anymore, but their 80mm Austrian Noctua fan looks like the one I bought. It's rated at 17 db. and has an oil bearing motor. In my PS Audio Power Plant, it made for a significant reduction in noise. They sell other noise reducing items for electronics, useful stuff.
jeenie67
Re: Quiet fans?
« Reply #5 on: 24 Jun 2009, 11:13 pm »
I've put resistors in the lines of my Crown amps to slow them down to a breeze. Also I use "Whisper" fans (trade name, absolutely quiet). Research online with computer cooling fan will produce numerous results. All different sizes and voltages are available.
srb
Re: Quiet fans?
« Reply #6 on: 25 Jun 2009, 12:24 am »
I used the Noctua fans in my HTPC which sits in my A/V rack.  No fan is silent, but they're pretty quiet.  Also they have a long MTBF.
A larger 120mm fan running at a slower speed to produce the same airflow as an 80mm fan will be a little quieter, so I would go for the 120mm if you can accomodate it.
