Jeweler's loupe to examine stylus?
0 Members and 1 Guest are viewing this topic. Read 2045 times.
toobluvr
« on: 18 Jun 2009, 06:41 pm »
I'd like to get a good, clear and up close look at my stylus.
Any of you guys using a loupe for that?
Does it work well?
What magnification do you recommend?
John
twitch54
Re: Jeweler's loupe to examine stylus?
« Reply #1 on: 18 Jun 2009, 07:56 pm »
While it will provide 5-10x (on avg) magnafication, it will by no means give you what a mocroscope will provide. the're cheap enough, so if it gives you peace of mind ....go ahead !
lcrim
« Reply #3 on: 18 Jun 2009, 09:32 pm »
I've had an inexpensive loupe bought on ebay a few years back.  I use it to check if the stylus is damaged or dirty.  Why would you want more detail than that?
Sorry, I did check my history on ebay and checked the loupe but no details but it was less than $5.  I use it regularly.
Wayner
« Reply #4 on: 18 Jun 2009, 09:42 pm »
If you have a local jewler that you are friendly with, I'm sure he will put it under one of his better powered scopes to help you out. I have a friend that is a jeweler and said to bring it over anytime.
Wayner :)
twitch54
« Reply #5 on: 18 Jun 2009, 10:09 pm »
for those 'analy' inclined .................
http://www.audiokarma.org/forums/showthread.php?t=87723&highlight=stylus+microscopes
but I do agree, for casual inspection, cleaning of the crud , etc ,10x should suffice.
toobluvr
« Reply #6 on: 18 Jun 2009, 10:34 pm »
I'm pretty anal...but not microscope anal!
 :lol:
Like you Icrim, I simply want to check stylus condition.
Also, awhile back I managed to bend my cantilever a bit.   :duh:
I put it back as best I could, and I'd like to see how the repair turned out.
So....what power do I need?  10X?  20X?
Maybe I'll just get both.  I checked Amazon and I'm surprised at how cheap they are.
