Nuforce IA7 V2+Fostex
0 Members and 1 Guest are viewing this topic. Read 2012 times.
linnea
« on: 18 Jun 2009, 12:13 pm »
What about IA7V2 with Fostex FE108E Sigma DIY project, like this?
http://www.fostexinternational.com/docs/speaker_comp/pdf/recom_enclose/108ez_encl.pdf
Did somebody try it? :scratch:
« Last Edit: 18 Jun 2009, 08:53 pm by linnea »
Norman Tracy
    • Audio Crafters Guild
Re: Nuforce IA7 V2+Fostex
« Reply #1 on: 18 Jun 2009, 08:23 pm »
Hello Nedo,
I have experience with a similar setup. My pair of FE108Esigma drivers are in this Fostex backhorn design for the FE103e:
http://www.fostexinternational.com/docs/speaker_comp/pdf/recom_enclose/103e_encl.pdf
My build is to the plan except the the side panels are double thick.
I built these during my single ended triode amp experments. I was disappointed. They sounded very good just not enough better in the bass to justify the extra cost and work on the back horn over a smaller stand mount reflex box.
Some time (years) later and I hooked them up to one of my ACG 1000 amps.
WOW
Now we have bass worthy of all the effort that goes into a back horn. And of course the great phase coherent sound one goes to a driver like the FE108Esigma for.
So if you are drawn to the full range driver sound do try them with class D amps.
