modifications to the P9
0 Members and 1 Guest are viewing this topic. Read 1163 times.
maligue
« on: 17 Jun 2009, 11:50 am »
To Jason:
I took delivery yesterday of the P9 that had been ordered since March (from Switzerland; the local dealer was exceedingly kind by simply putting his own units at my disposal in the interim).
I immediately discovered two differences between his and the brand new units:
(1) the input selection knob on the Control Box does not 'push in' to turn the P9 on/off. The units can only be turned on/off from the RC.
(2) the dimmer kicks in automatically, i.e. I did not set it from the RC as described in the Manual.
The second difference - if it is one - is cosmetic and of no great importance. However, the first should be clarified, I believe.
Has NuForce modified the design, or have I received a faulty unit?
Thnaks in advance for some feedback
edward
rustydoglim
    • www.nuprimeaudio.com
Re: modifications to the P9
« Reply #1 on: 23 Jun 2009, 11:35 pm »
Hi,
No we didn't change it. You should be able to push one of the knob to turn on/off (did you try to push in and hold it anyway?). The dimmer might have been set at factory but you should be able to reset it. Please contact [email protected] to resolve this.
jason
