0 Members and 1 Guest are viewing this topic. Read 6066 times.
If you want higher efficiency and smallish size that by laws of physics means a lot less bass. Its called Hoffman's iron law. In order to get the same bass response as lower efficiency speakers, higher efficiency speakers need to be much larger.
Quote from: JoshK on 17 Jun 2009, 01:23 amIf you want higher efficiency and smallish size that by laws of physics means a lot less bass. Its called Hoffman's iron law. In order to get the same bass response as lower efficiency speakers, higher efficiency speakers need to be much larger. I'm afraid that's a fact. Which is another advantage of active desktops. I think I'll bow out at this point. I think most SET's are distortion machines, and I just can't see designing a speaker that's designed to work well with gobs of harmonic distortion and an uneven frequency response.
Quote from: DMurphy on 17 Jun 2009, 01:40 amQuote from: JoshK on 17 Jun 2009, 01:23 amIf you want higher efficiency and smallish size that by laws of physics means a lot less bass. Its called Hoffman's iron law. In order to get the same bass response as lower efficiency speakers, higher efficiency speakers need to be much larger. I'm afraid that's a fact. Which is another advantage of active desktops. I think I'll bow out at this point. I think most SET's are distortion machines, and I just can't see designing a speaker that's designed to work well with gobs of harmonic distortion and an uneven frequency response. Not a SET man Dennis?
Are you talking in the neighborhood of 8 watts? If you were at 40+ watts you'd be able to drive just about every speaker offered to decent levels.
A standmount speaker the size of the HT1 with 95db/w sensitivity would be lucky to have a -3db down point at 300hz. I don't mean to rain on your hopes, I own a SE amp too. But these are just the facts.
So not much love for the SET in the Salk Circle... I must say I'm a little surprised. It seems that for those of us afflicted with auphiophilia to the extent that we would hunt down a small custom speaker manufacturer in Michigan, the SET world would be right up our alley. Is it just me? aa
I understand the advised approach is to decide on speakers, then select an amplifier to drive the speakers, rather than deciding on an amplifier and then be limited to speakers that the particular amplifier is capable of driving. There are some very fine higher wattage tube amplifiers available, and a decision to use tube amplification should not be an obstacle to purchasing speakers.
